Author Topic: holley carb question  (Read 6881 times)
Offline 1984k30
« on: February 15, 2010, 07:31:54 pm »
I have a holley carb on my truck and it leaks fuel.  It is coming from the bottom of the front float cover.  I think the piece is the accelerator pump not sure though.  It is about 1 inch by 1 inch and has 4 screws holding it on.  can I purchase this gasket or do I have to buy the whole kit.  Trying to find out what model it is.  The list number says 8700 and then 1571.  Any one know how I can find out the model it is.
Offline Josh454
Re: holley carb question
« Reply #1 on: February 16, 2010, 08:07:16 pm »
I think you'll find that is an old school 600-650.  The date code is for 1971 so I full on rebuild kit would probably be a good idea anyhow...
Offline eventhorizon66
« Reply #2 on: February 18, 2010, 03:15:04 pm »
The leak source that you described is the accelerator pump.  The gasket is integral to the pump diaphram.  They are cheap to replace and come in 30cc (the one you should have) and 50cc versions.  Full rebuild is not a bad idea.  If I were running a Holley, I'd probably rebuild it once a year (in an ideal world where I'm not so lazy).
'85 C10 SWB 350 700R4 TKO600
Offline 1984k30
« Reply #3 on: February 18, 2010, 05:24:14 pm »
Got a hold of holley today and said it was a q-jet replacement model 4175.  Summit has a rebuild kit for 80 bucks.  I going to order the kit but not sure if I am going to rebuild the whole carb.   I hate to tear the whole thing apart because it works perfect now.
Offline ohio hab
  • 1984 C-10, 383 SBC
« Reply #4 on: February 18, 2010, 05:51:56 pm »
Jeg's has just the accelerator pump, 30cc- 2.99, which is more likely what you have, or 50cc- 13.99, if carb is working fine I would just replace the accelerator pump. Part # 510-135-5 for 30, and 510-135-7 for 50.
Offline 1984k30
« Reply #5 on: February 18, 2010, 06:56:52 pm »
thanks for the info.  I always forget about jegs.  I will check it out tonight.
Offline TexasRed
« Reply #6 on: February 18, 2010, 09:00:12 pm »
Most part stores have the accelerator pump. Unless you get the big rebuild kit from summit, it won't have the dual stage power valve, just the single stager. So you'd have to reuse your old one.
Offline Josh454
« Reply #7 on: February 19, 2010, 08:42:03 pm »
Is the carb a square or spreadbore?
Offline 1984k30
« Reply #8 on: February 19, 2010, 08:47:30 pm »
It is a spreadbore.  I am thinking it is a older model.  All of the 4175's that I see on summit and jegs have a electric choke.  Mine uses the intake manifold.
Offline Josh454
« Reply #9 on: February 20, 2010, 02:49:39 pm »
I'm sure you could convert it to electric if you wanted to.  The 4175 is really a great carb.  It's has many of the benefits of a holley and a Q-jet.
