Author Topic: 81 Crew cab dually 2wd CUMMINS  (Read 131292 times)
Offline Pullin81
  • MY86
Re: 81 Crew cab dually 2wd CUMMINS
« Reply #45 on: June 26, 2010, 12:11:46 pm »
well i actually cut the first cross memeber under the box for it to go threw im just going to have another bent and stick it behind it... shouldnt really be a big deal anyways....if youy want the pipes threw two spots and  go under the frame and well ive got just under three iches from the frame to the ground and the pipes are 5". im going to cover my t pipe up and mount my compressor and air tank and then cap that all off aswell with diamond plate
86 gmc short box...454/th400
81 gmc crew cab dually bagged 5.9 cummins/nv4500
Offline 89_Chev_Cummins
  • New Users
« Reply #46 on: June 30, 2010, 05:10:16 am »
Looks Bad Ass!!!!I Also Have a Chevy Dually With A Cummins...Check It Out...
Offline Pullin81
  • MY86
« Reply #47 on: June 30, 2010, 10:44:36 pm »
right on.... do you have any build pictures or other pictures of the truck
Offline Edahall
« Reply #48 on: August 05, 2010, 01:26:21 pm »
Here's a few pictures of my Cummins powered Suburban.  It pulls like crazy and best of all, I'm getting 26 mpg on the highway.
1990 ¾ ton 4x4 Chevy Suburban
-Gear Vendors Overdrive
-Upgraded Holset HX-35 turbo
-NP205 iron transfer case
-3.73 gears
-2" Lift
Offline Leroy Rochester
  • New Users
« Reply #49 on: August 27, 2010, 12:41:31 pm »
Man, this is really cool. I've been thinking alot about doing this with my '87 R30. Did you have to modify the cross member under the engine? I saw you'd said that you'd modified the support under the blancer but I'm not picturing which support you modified. Thanks! Keep up the good work and good luck!
'87 R30 crew cab dually
Offline Pullin81
  • MY86
« Reply #50 on: August 29, 2010, 11:29:27 am »
well i just thought i would let evryone know that was keeping and eye on this thread that it is no longer. I sold the truck as a roller yesterday...looking for a 4x4 now
« Last Edit: August 31, 2010, 04:03:15 pm by Captkaos »
Offline Pullin81
  • MY86
New Crew cab 4x4 cummins project.
« Reply #51 on: October 18, 2010, 11:42:26 am »
well i bought another crew cab..you may remember the bagged crew cab dually i was building with the cummins...well i sold the truck and decided to go up instead of down....its an 1985 GMC K3500 welfare model...there isnt even an interior light in it...It has a running 350/4sp manual which is perfect for my cummins swap... the only problem that in a little sketchy on is the front drip rails here missing for how long i dont know.
Alot of the steel on the truck needs to be replaced but thats fine im not shooting for nut and bolt resto on this on its just onna look cool and be functional.
my plans are to go threw all the steel...cab corners, rockers, new doors, short box conversion, install a 8 inch lift and 37" tires, fab bumpers which i have a local guy in town doing for me that used to build alot of them...stick the 12V  in the truck with the 5 speed, and run a devorce transfer case ...
heres some pics from my phone the truck looks alot better in the pictures than it does in real life....its gonna be some work but it will be worth it in the end....i plan on doing every bit of work to this truck on my own with the exception of the bumpers cause it was a little trade deal we had.
Offline Grim 82
Re: New Crew cab 4x4 cummins project.
« Reply #52 on: October 18, 2010, 11:45:55 am »
Looks like a real good platform to start with.
Offline 1HI4x4
  • V30 Crew now a shortbed.....
« Reply #53 on: October 18, 2010, 01:46:14 pm »
If your going to do a 5 speed, just get one out of a 4x4 and you won't have to do the divorced transfer case.
1988 V30 Crew Cab, Cummins power, 47RH-NP205, 8" lift, 13.50x35x20 Fuel Mudders on 20x14 XD Diesels -76 offset. Soon to be repainted, seats from a 2010 Lariat to be installed.
Offline Pullin81
  • MY86
« Reply #54 on: October 19, 2010, 06:29:09 am »
i would go with a 4x4 unit...but i had the 2wd unit for my dually i was building that i sold that has never been used....
Offline 1HI4x4
« Reply #55 on: October 19, 2010, 12:38:04 pm »
Allrighty, there is a guy in Illinois that rebuilds NP205 Divorced Transfer cases if you are looking for one. Google Moonshine Mafia Motorsports you'll find him.
Offline Pullin81
  • MY86
« Reply #56 on: October 24, 2010, 09:49:07 pm »
well ive been slacking so quick update....i aquired another crew cab due to rust on the other cab that i didnt want to deal with.... might have been fine but i dont need it to rust out in a few years after its all done...i want to drive this unit full time....so i got a 2wd crew cab from a guy ive done some work for in town told me i can have the truck if i pull the engine....so the last 2 days myself and a few buddies tore out drivelines and front ends, and cabs i put the 80 cab on my 4x4 frame whish i kind of like the 73-80 front end they look more " heavy duty". Also ordered a crossmember from avalanch engineering, and searching for a 8 inch lift that om hoping to have for next weekend....
Offline Layne
« Reply #57 on: October 24, 2010, 10:08:43 pm »
Uh-Oh I see an open seal ;)
Offline Lucky Jeff
« Reply #58 on: October 24, 2010, 10:55:25 pm »
Can't wait to see the finished product! I'm rather fond of those ole dinosaur motors  8)
77 4x4 small block shorty
98 Ram cummins with a few mods
96 Grand Cherokee
Offline Engineer
« Reply #59 on: October 25, 2010, 07:50:24 pm »
That guy has a few divorced NP205s on ebay almost all of the time. I had a divorced 205 from a Dodge many moons ago, and sold it for next to nothing. Didn't need it but have wished I would have kept it.
1997 Chevy Blazer 4x4
1979 Chevy K-30 4x4 4sp 4.10
