Author Topic: big block to small block  (Read 11864 times)
Offline malibu795
Re: big block to small block
« Reply #15 on: February 27, 2010, 09:29:00 pm »
Why not fix the 454? The flexplate may be different. Do you know if it's internal or external balance? What year sb are you planning on installing?
bolt patterns are identical.. at least of the Gen IV BBC and 2 piece SBC(gen 1/2?)
i havent seen a factory ineternal balance BBC
BBC(454) are external and have more weight out there then a SBC 400
kinda off the track there
adam wildman
75 K25 383/400
« Reply #16 on: February 27, 2010, 09:37:49 pm »
So are you saying the 454 is the only bbc? And are you saying sbc are not also internal and external balance? Totally confused on what you're trying to say here  ???
Offline malibu795
« Reply #17 on: February 27, 2010, 09:43:59 pm »
same the bolt pattern between the flex plate and crank are the same between the two engines.
the two main diferences is 153/168t and balance set up.
pending how tight money si one could cut the weights off a BBC flex plate and zero it out.... still probly be cheaper to bu a jegs/summit
knock off flex plate
adam wildman
75 K25 383/400
Offline Torque454
« Reply #18 on: February 28, 2010, 11:10:05 pm »
Got full length headers on my 79 C10 w/ 454. They are even cheapies from oreillys. Only problem I am having is that I cant get a straight pipe off  the headers into my muffler on the drivers side because there is no hump in the crossmember. The headers fit just fine otherwise tho, I removed the spark plugs and pushed the headers up from the bottom. Didnt have to lift the engine up or anything.
