Author Topic: 75' gauges in an 81'.  (Read 10084 times)
Offline 327power
« on: February 25, 2010, 08:53:52 pm »
Ok...I have an 81' C10 that has a very noisy speedometer. I got a instrument cluster from a 75' C20, but it has a mechanical oil gauge. Can I still use any of it? Thanks.
LIVE FREE OR DIE
Offline slammed79
  • Thou shalt not drive stock
Re: 75' gauges in an 81'.
« Reply #1 on: February 25, 2010, 09:44:46 pm »
You can swap the speedos without any issue based far as I know. I'm sure if I'm wrong someone will chime in.
Praise the lowered
Offline 78 Chevyrado
  • Z62 ON-ROAD
    • My Photobucket Site
« Reply #2 on: February 26, 2010, 09:06:13 am »
Dont use the AMP guage from the older truck or there'll be smoke and flames.
« Reply #3 on: February 26, 2010, 09:56:06 am »
The actual speedo gauge is making noise or the cable going to it?
Offline 1980c10
« Reply #4 on: February 26, 2010, 06:07:18 pm »
My bet also would be the cable if you haven't ruled it out. If it is just take it out and lube it.
Offline 327power
« Reply #5 on: February 28, 2010, 10:49:50 pm »
Yeah, it seems to be coming from the speedometer. While driving, if I put my finger on the speedometer I can actually feel the vibration. Super annoying.
LIVE FREE OR DIE
Offline slammed79
« Reply #6 on: March 01, 2010, 08:10:06 am »
Still could be the cable, try lubing it first, they like it periodically
Praise the lowered
Offline 1980c10
« Reply #7 on: March 01, 2010, 05:57:21 pm »
Mine was the same, lubed the cable, now nice and quiet.
« Reply #8 on: March 01, 2010, 06:13:26 pm »
Its' the cable.  There is nothing in the gauge that will make that much racket.
Offline 327power
« Reply #9 on: March 01, 2010, 08:08:46 pm »
It appears to be a 2 piece speedo cable...should I replace the whole thing? It also leaks from the cable connection at the transmission. Just so you know. Thanks!
LIVE FREE OR DIE
« Reply #10 on: March 01, 2010, 11:16:48 pm »
Pull it out and look at it.  If it is dry you need to lube it.  If it is frayed, you need to replace it.
Offline 327power
« Reply #11 on: March 13, 2010, 10:48:32 am »
Well, I pulled out the cable a couple days ago and apparently it was loose at the speedometer. I bought a crappy "replacement" cable from a chainstore and it doesn't work 'cause it has a threaded connection that is supposed to fit the gauge. Of course it is a slip on so it won't work.
I going to just put on the old one and see if it stays on the speedometer tight enough that it won't loosen up. I think that is why it was noisy in the first place. Thanks!
LIVE FREE OR DIE
« Reply #12 on: March 15, 2010, 04:43:07 pm »
I think you can still get the actual inner cable from NAPA.
