Author Topic: K20 to K10 trans swap  (Read 3934 times)
Offline birdy411
« on: March 01, 2010, 05:44:53 pm »
Wanting to swap trans and transfer case from 3/4 ton truck to half ton truck. This is the manual trans.
Can i do this, or are there different gear ratios, etc....that will affect speedometer, etc.
thanks
1978 Chevy K10 Scottsdale
1979 Chevy K10 Custom Deluxe
1980 Chevy K20 Scottsdale (Parts)
1978 Chevy C10 Silverado (Parts)
Re: K20 to K10 trans swap
« Reply #1 on: March 01, 2010, 05:57:07 pm »
Ratios are determined by the speedo gears which are set to the original trucks trans and gear ratio.
As far as swapping them out you will have not HUGE issues.
« Reply #2 on: March 02, 2010, 02:40:15 am »
other things to look at are spline counts for the drive shaft but most of all a new drive shaft if yours is a standard bed and the 3/4 is a standard bed then your alright but if your is a standard and the other is a long then you might have a custom shaft or find one to fit
Offline birdy411
« Reply #3 on: March 04, 2010, 03:16:53 pm »
Good to know, thanks!
