Author Topic: 77 shortbox lift ideas  (Read 21651 times)
Offline Chevalade
Re: 77 shortbox lift ideas
« Reply #15 on: March 03, 2010, 08:02:29 pm »
I actually just got that same lift. Comes with all the bolts and parts. Pretty decent for the price. But the front springs are way stiff, you will either want a diesel or a big block on them. I am ditching the rear blocks and using the shackle flip kit from DIY4X. Also got the zero rate blocks, just in case I wanted a lil more lift.
I am prolly going to go with crossover steering, as the stock has bumpsteer. (buddy just did his and has bad bumpsteer)
I shoulda bought the sway bar drop, but will prolly make a drop/disconnect setup.
Shocks are decent, nothing special. I bought some very slightly used bilstein 7100 remote reservoirs. Will run the RC's till I can get longer shock towers (ford).
Offline 77chevyshortbox
« Reply #16 on: March 03, 2010, 09:53:56 pm »
this shackle flip kit, what exactly is it called, and how much does it go for you think. plus if i flip the shackles and say throw some leaf springs in there could i get by fitting 36's, the truck has no springs or coils in the front, just leafs and a single shock. thanks for the help guys
Offline 4x4orbust
« Reply #17 on: March 03, 2010, 10:17:07 pm »
this kit: http://diy4x.com/cart/index.php?route=product/product&path=24&product_id=125
you can buy longer shackles to get a 6" lift out of it.
Offline krafty33
« Reply #18 on: March 04, 2010, 12:21:29 am »
I just put a 4" rough country kit in mine with new springs all around. I put 35X12.5X15 tires on mine. I have to do very little trimming on the fenders. I understand you are looking at the 6" so 36's shouldn't be a problem. If money is the issue, hold of and get the kit with all new springs. I am glad I did.
« Reply #19 on: March 04, 2010, 02:45:56 pm »
so this shackle kit will lift my rear end. then what exactly do i do to the front end?
Offline 4x4orbust
« Reply #20 on: March 04, 2010, 05:22:37 pm »
you would have to buy some 6" lift front leafs, (to match the rear), a dropped pitman arm (or drag link) for the 6" lift, and then drop the sway bar to match the lift.   none of thee are hard to do, just time consuming if it's your first time.   if the truck is going to be driven on the street, the sway bar is a necessity.
« Reply #21 on: March 04, 2010, 05:59:04 pm »
on roughcountry theres an adjustable drag link, would that work for the pitman arm drop?
« Reply #22 on: March 04, 2010, 08:39:19 pm »
I would go with new springs due to you old ones are prob 33 years old. And worn out its only a couple hundred more
« Reply #23 on: March 04, 2010, 10:44:56 pm »
my truck doesnt have springs. just leafs
« Reply #24 on: March 04, 2010, 11:16:52 pm »
Do you mean like this?
Cuz otherwise leaf springs are springs.
« Reply #25 on: March 05, 2010, 09:27:29 am »
If leaf springs are leafs what does that make spring leafs
« Reply #26 on: March 05, 2010, 04:37:00 pm »
lol i thought you meant coils sorry.
Offline big trucker
« Reply #27 on: March 05, 2010, 08:22:45 pm »
you could save a little do a 4 inch life front springs rear blocks raised steering arm longer shocks make brackets to lower the brake lines using the stock lines and put a 2 inch body lift in
