Author Topic: oil pan touching cross member  (Read 3816 times)
Offline chadlovelady
« on: March 12, 2010, 10:05:12 am »
i've got a 85 3/4 ton 4x4,just pulled my old 454 and put in a 496 stroker, the new motor has a 6 quart oil pan that is touching the cross member,,my question is,,is there some motor mounts that will raise the motor up enough to clear?
1985 GMC 4x4 3/4 ton
496 Stroker
Offline 78 Chevyrado
  • Z62 ON-ROAD
    • My Photobucket Site
Re: oil pan touching cross member
« Reply #1 on: March 12, 2010, 10:17:38 am »
Maybe put in a spacer between the mounts and the frame?  how much lift do you need?  depends on how much it will be moving when you romp on it.
« Reply #2 on: March 12, 2010, 10:49:18 am »
i would need at least 1" of clearance.
496 Stroker
« Reply #3 on: March 12, 2010, 12:21:16 pm »
OK,,,i contacted Kert @ DIY4X ,, he is going to build me some custom mounts to clear my cross member  ;D
496 Stroker
Offline HAULIN IT
« Reply #4 on: March 12, 2010, 05:45:09 pm »
Why not alter the crossmember (it bolts in) to clear the oil pan? Moving the angle of the whole engine/transmission/transfer case to account for having a bigger pan doesn't seem like the right way to go to me. How about picking up an extra crossmember & cutting/welding a shape like this \___/ into the center or if you really only need an inch, just notch the crossmember & plate it in & maybe add a 1" x 3" or 4" rectangle tube on the bottom? My Two cents, Lorne
