Author Topic: Having a little engine trouble...  (Read 10567 times)
Offline Gregzz4
Re: Having a little engine trouble...
« Reply #15 on: March 30, 2010, 09:40:55 pm »
At this point I would recommend you have someone hook up a scanner and see what codes come up, before you pull your hair out or throw a bunch of money @ good parts
'78 1/2 Ton
GMPP ZZ4 Q-Jet
700R4 Race Internals
3:42 Eaton
« Reply #16 on: March 31, 2010, 05:35:05 am »
So it’s not a firing problem and not a fuel problem so it has to be a sensor. something’s it could be fuel pump being week due to when cold the engine needs more fuel to idle but you said you replaced that. The idle air control valve or the egr. Like greg said pull the code if there is one and see what it says. Also im thinking the iac for some reason
« Reply #17 on: March 31, 2010, 08:00:37 am »
check your fuel pressure
Offline jamiebarnesjr3
« Reply #18 on: March 31, 2010, 01:15:24 pm »
theres a 4 prong plug to the left of the dizzy try unplugin for a min and plug back in if that works just buy a dizzy with out that plug and also check that ur choke is working properly
