Author Topic: Evap code won't leave me Alone!!!  (Read 11774 times)
Re: Evap code won't leave me Alone!!!
« Reply #15 on: April 12, 2010, 07:46:54 pm »
Make a different thread for the other car if you want help with that one
Offline Josh454
« Reply #16 on: April 12, 2010, 07:47:35 pm »
Well...there are two ways to go about it at this point.  You can take it to someone qualified you can accurately diagnose the system (provided it's a hard fault, not intermittent) or you can shotgun parts at it.  My bet would be a vent valve or purge valve.  Both are pretty cheap.  That's where I would start if I was a betting man.  But I should clarify that I am not a betting man!
Offline autorepr
« Reply #17 on: April 15, 2010, 09:23:31 am »
Howdy,    .1 times it's a leaking gas cap. 9.8 times out of ten its a hole in one of the EVAP hoses that run from the engine compartment to the tank area. The actual hoses themselves are plastic and aren't normally a problem but the rubber hoses that connect them together and to the system componants are. The get eaten up by the fuel vapors and then split. All you have to do is trace the hose set that has the little green cap fitting in and you'll find it. Feel all of the rubber connectors for a split or rupture with your hand (it's always on the opposite side that you can readily see) and then replace it. You should get it from the dealer (they'll have a barrel full of each one). The other .1 time is the actual vent valve, they suck in dirt and then the valve doesn't seat. Replace that dude with one from the dealer and you'll be fine. (they're are under $30 or $40)
Offline Layne
« Reply #18 on: April 15, 2010, 07:17:00 pm »
Thanks for the input, guys. I'll report back as soon as I get some time to work on it.
