Author Topic: Bigger Radiator  (Read 5640 times)
Offline Tazman
Bigger Radiator
« on: March 20, 2010, 11:38:54 am »
I am looking to have no worries when it comes to driving when it is 100 degrees here.So I am considering putting a radiator from a 6.2 diesel in to my 350 can this be done ?Thanks
God BLESS AMERICA
Offline Da67goatman
  • Burban
Re: Bigger Radiator
« Reply #1 on: March 20, 2010, 02:23:11 pm »
Yes it can be done and is relatively simple.  Make sure you flush the all diesel oil out though.
<Pitcrew>
Re: Bigger Radiator
« Reply #2 on: March 20, 2010, 08:22:33 pm »
Ive got a 4 row for a bigblock in most of mine, and never have had any troubles. And before too long, 100 degrees will be normal here for a while. I dont know what the difference between the deisel and the gas radiator is.
Offline 1984k30
Re: Bigger Radiator
« Reply #3 on: March 20, 2010, 08:46:20 pm »
The diesel is at least 6 inches longer.
Offline Lt.Del
  • Andy aka:SgtDel
  • DelbridgePhotography.com
    • www.delbridge.net
Re: Bigger Radiator
« Reply #4 on: March 20, 2010, 11:59:22 pm »
a 4 row is all you need.  I pull a 7,000 lb camper trailer in the summer and have no problem at all with heating issues.
Some say the newer type aluminum 2 or 3 row radiators are comparable.  I cannot testify to that since i've never had one.
I know this doesnt answer your question about the diesel radiator, but, I dunno.  ???
Offline youngblood222
Re: Bigger Radiator
« Reply #5 on: March 24, 2010, 10:57:04 am »
i have a 4 row bigblock  trans cooler and a remote oil cooler i have trubble gitin it above 130  when is 110 out side mite not ansere ur qusten but i had a heating problem before i added all the cooling system
74 432cid small block
Offline ohio hab
  • 1984 C-10, 383 SBC
Re: Bigger Radiator
« Reply #6 on: March 25, 2010, 08:05:04 pm »
I have an aluminum 3 core, in my 1984 C-10 with a built small block, and never owned an aluminum radiator before. The engine has an high volume older USA made Wiend water pump and the engine has a hard time getting above 150. I had to block off part of the radiator. The representative of the radiator shop said I only needed a 2 core, he was right. Too cool of an engine is a nice problem to have. I firmly believe aluminum cools better than my old brass radiator.
