Author Topic: new pics/video of my 86 k10  (Read 6071 times)
Offline screamin86
« on: March 21, 2010, 06:51:24 pm »
im still in need of a good exhaust setup so any suggestions would be nice lol. it has long tubes 2 1/2 y into 3in cat that i had to get since it got clogged and about 3foot of pipe after with a turndown at driver side rear tire. i still need to shim my starter and do some more tunning ive got about 300 miles on the new setup so far. engine bay isnt the cleanest still  need to get some better wires and install my f-body electric fan :)
86 ta:lm7 hot cam boltons
Offline Jesse Walter
Re: new pics/video of my 86 k10
« Reply #1 on: March 21, 2010, 07:09:25 pm »
Sounds sweet.
You should get dual 3" and dump them behing the back tires.  I think some regular turbo mufflers would do the job.
Jesse Walter
86 K20 4x4
86 C30 Dump
Offline screamin86
« Reply #2 on: March 21, 2010, 07:45:47 pm »
actualy lol if you look on the video or the ast pic of the truck you can see on the ground was the exhaust i started building for one of my f-bodys its 3in with x pipe and i have two summit 3in turbo mufflers that goes with it. ill need to buy new hedman s pipes if i use it since my car had ball socket collectors instead of ones that use gaskets liike the truck has now. i just dunno if i wanna run the turbos or not though. :/ i will say the truck needs regeared though but it needed that before the new motor. it has 3.42s at a minumum of 3.73 but prefer 4.10 or 4.56's.
« Last Edit: March 21, 2010, 07:49:00 pm by screamin86 »
« Reply #3 on: March 22, 2010, 11:36:23 am »
I've got 2 1/2" flowmasters on mine.  Its a little loud but not too loud.  I've always liked the sound of Walker Dynomax turbo mufflers.  They are quiet at idle but when you hit the gas you can really hear it.
Jesse Walter
86 K20 4x4
86 C30 Dump
Offline Prong
« Reply #4 on: March 22, 2010, 03:50:06 pm »
You'll want to replace that plastic fuel filter with a metal one before it melts and burns the truck to the ground.
79 K10 SB 4x4 383/Th350
79 K10 LB 4x4 350/SM465
