Author Topic: Pipe question.......X, H, L WTH?  (Read 5432 times)
Offline Zeked
« on: March 26, 2010, 09:32:32 pm »
Can someone give me an opinion of why an exhaust needs an "X" or "H" shape?
I assume that it is not legal to do away with the Cat Converter on an '87 5.7 tbi........... ::)
Thanks
Zeke
Often Wrong......Never in Doubt!
Offline jd4020
Re: Pipe question.......X, H, L WTH?
« Reply #1 on: March 27, 2010, 01:06:46 am »
for one it makes it sound better. true duals that aren't connected tend to sound like two 4 cylinders fighting each other
76 K20: 350 4 bolt main, RV 5800 cam, 9:1 pistons, weiand high rise, built carb, headers
87 Ford F150
« Reply #2 on: March 27, 2010, 01:44:08 am »
kind of  like what jd said but its not just the sound its so the both sides of the engine are working togeather not just working the reason i think most people h pip is cause its simple to do its just like running duals but you just connect them an x pip you have to work around allot more to get them to meat in the same spot. no its not legal to get away with the cat but if you don't have inspections every year or two no one knows unless you get too loud and cause the cops to check it out or give you an inspection sticker. now also i had my truck with punched out cats and glass packs that dumped right before the tire true duals but nothing connecting them it sounded real good but it lost tq due to not have the back pressure of a cat or h or x pipe you need something there a couple bends or something
Offline Chevalade
« Reply #3 on: March 27, 2010, 03:45:44 am »
X has proven scavenging benefits.
Offline Layne
« Reply #4 on: March 28, 2010, 12:03:56 pm »
When I got my exhaust was done, I wanted an X, but the guy said he couldn't build one up. We discussed the benefits of an H or an X and he said the X was more beneficial at high rpms, like 8,000 rpm and so on.
