Author Topic: is there a differance  (Read 3537 times)
Offline jamiebarnesjr3
« on: April 01, 2010, 09:40:33 am »
are canadian built k10 (specificly the short bed) and american built trucks differant. for example my canadian k10 4x4 swb sits around 3 inches higher then any other k 10 ive parked near and as far as i kno it doesnt have a aftermarket lift it does have 3 inch blocks under the springs in the rear but ive been told that was factory from canada? is this true are there any other things that r differant
Re: is there a differance
« Reply #1 on: April 01, 2010, 05:03:28 pm »
There isn't any difference.  There was tire size differences for them though which will make them shorter or taller depending on the option.
I have never seen a GM 73-87 with blocks in the rear.  I would assume you have a lift kit on it.
« Reply #2 on: April 01, 2010, 10:52:10 pm »
Ditto on the stock GM trucks never having any blocks between the springs, and axles.
