Author Topic: flex plate teeth number  (Read 4677 times)
Offline 84chevysilverado
« on: April 04, 2010, 02:19:25 pm »
I have a 1984 chevy with a 305 i bought a new starter which has 9 teeth does anyone no if i need the 153 tooth or the 168 tooth flex plate?
Re: flex plate teeth number
« Reply #1 on: April 04, 2010, 03:02:41 pm »
Did you compare it to your old starter?
Offline Lt.Del
  • Andy aka:SgtDel
  • DelbridgePhotography.com
    • www.delbridge.net
« Reply #2 on: April 05, 2010, 08:34:51 am »
someone correct me if I am wrong, but, if the starter bolt patter are in a linear line paralell with the engine block end, the starter is for a 305 w/ the smaller flexplate.  If the two starter bolts are off set, not in paralell with the engine block end, the starter is for a 350 or 400 with the 168 tooth flex.  At least that is what i read years ago somewhere and it seems to work when i strip parts off at salvage yards--that info works for my truck in matching up parts. I know I have the off set two bolt hole starter and i have the 168 tooth flex.
« Reply #3 on: April 05, 2010, 09:10:23 am »
no i cant compare it to the old one the guy thta had the truck before me put a new starter on and it grinds a bit. so i rebuilt the motor and i wanna fix this problem. i will let ya no how many teeth my flexplate has now.
« Reply #4 on: April 05, 2010, 06:46:05 pm »
There are two diffrent sizes on the flex plate about an inch diffrents if its grinding it should only need shims if it was the wrong size flex plate then I don't think it would contact at all
« Reply #5 on: April 06, 2010, 09:10:51 am »
ok maybe thats what was wrong i counted the teeth on the old one and it was 163
