Author Topic: K10 to K20 Conversion  (Read 47002 times)
Re: K10 to K20 Conversion
« Reply #15 on: May 25, 2010, 09:48:18 am »
  Thanks for the info,  I am new here and just started on my 74 stepside 4x4.  Since the cab is rusted out I planned on swapping it over to 3/4 ton running gear from a 80 3/4 4x4.  This answered my questions I had.  This forum is very informative.  Tom
Offline 77k10silverado
« Reply #16 on: July 11, 2014, 01:18:26 pm »
So whats the difference in the front 2 leaf vs. the 3 leaf K10 or K20? Could it have been because of the engine block size (weight) seems to me the 3 leaf would be a lot stiffer and harsh riding. Also is there any ride height difference between the 2 or just load strength? Nice thread with good info!
« Reply #17 on: July 11, 2014, 08:18:08 pm »
GVWR is the reason. it all depends on the condition of the springs, neg arch vs positive
Offline Engineer
« Reply #18 on: July 11, 2014, 11:05:15 pm »
I have never seen a K20 with 56" springs. All I have seen are 52". And every K30, both SRW, and DRW have been 56".
The spring center is the same for a K10, and a K20. All of the K30 spring perches are narrower than the K10/20 trucks to accommodate the inner wheels/tires on the DRW cab, and chassis trucks.
I have never been able to find a difference between K10, and K20 frames of same year models. The K30 frames however, are very much different than the others.
1997 Chevy Blazer 4x4
1979 Chevy K-30 4x4 4sp 4.10
« Reply #19 on: July 12, 2014, 09:45:27 am »
    This is true, the k30 frames are bigger (taller) than the others.
« Reply #20 on: July 12, 2014, 11:11:15 pm »
there is no difference in the frames of a c10 or c20. you will only find different springs axles and brakes this goes for k10 and k20 also
