Author Topic: Popping when i back up  (Read 4388 times)
Offline slimpickens8
« on: April 08, 2010, 08:16:09 pm »
So i hear a popping when im in reverse. I thought it was in the rear end but my neighbor says it sounds like its in the barke drum. Im gunna take it apart this weekend and get to the bottom of it but until then any specaliation on what it could be??
Re: Popping when i back up
« Reply #1 on: April 08, 2010, 08:54:07 pm »
Is it front or rear. If its front, It could be ball joints or??
« Reply #2 on: April 09, 2010, 12:31:10 pm »
Is it a ting more than a pop, does it do it constantly or once every time u back up, ex. Once every time the drive shaft or wheel rotates
« Reply #3 on: April 09, 2010, 02:35:42 pm »
O and it only happens when im turning while in reverse. AND  yes i believe its consistant and its more like a popping sound
« Reply #4 on: April 09, 2010, 06:54:43 pm »
Does it do it in 4wd or just 2 also what about when you ride the brakes and rev at the same time
Offline frogman68
« Reply #5 on: April 10, 2010, 04:45:47 am »
If its coming from the drum its more than likely something with the Brake Adjuster
