Author Topic: Where on the distributor cap does number 1 spark plug wire go on a 350 Chevy?  (Read 27821 times)
Offline exodus138
i have a 79 blazer 5.7 liter and i changed the cap but pulled all the wire plugs off the cap and dont know where the #1 goes any help?
Offline exodus138
when i pull the #1 plug do i have the ditributer cap off while turning the engine?
After you get the engine to TDC, you will need to know where the rotor is to place the #1 wire properly.
Offline exodus138
i have a comression tester i can plug that into #1 and whent its at tdc what should compression be?
You will only have compression on the compression stroke. When you start to build compression, then look at the timing marks on the balancer to line it up.
Offline exodus138
do i crank it with the ignition or by hand? if by hand how do i do that? sry for all the ?s am a newbie.
If all you did was pull the wires off, you shouldn't have to find tdc
I thought I posted on here before, but it looks like it disappeared.If all you did was remove the cap, and wires, this should help. The only time you need to worry about TDC is if you remove the distributor, or if someone else did in the past and put it in wrong. Put it back together this way, and then if it doesnt work right, we'll help find TDC.
Offline exodus138
thanx i puled the distributer cus i had to change the intake gasket. u all are awesome it worked!!
