Author Topic: Slightly dissappointed  (Read 12897 times)
Offline Gregzz4
Re: Slightly dissappointed
« Reply #15 on: April 15, 2010, 10:57:43 pm »
I would think your initial timing should be @ about 10 Degrees, but double-check that with someone
You may benefit from a little higher initial timing ( mine's @ 11 but I could get 12 maybe after I fatten up my primary circuit in my carb ), but you'll need to listen for knock under mild load, like uphill, so you don't get detonation
I can't push my timing up too much because of my Compression.....you may be able to go higher with your setup. Just don't let it Ping
Total timing may be OK up to 36 Degrees, depending on your parts and the Octane
Mine is OK @ 36 due to my Octane....no knocks/pings
Most pump fuel racers don't go above 36
'78 1/2 Ton
GMPP ZZ4 Q-Jet
700R4 Race Internals
3:42 Eaton
Offline tkleinia
« Reply #16 on: April 15, 2010, 10:59:33 pm »
It has a brand new trutrac in the rear, and will burn the 33 12.50s into 2nd gear... evertyhing holds up...
My issue is from a standing start, and lack of power up hills.
If I floor my 94 (150k mile)chevy going up a hill, it climbs right up to 80mph (or however fast you like)
But my 5,000 dollar(engine cost alone) 383 fights to hold 60mph
Offline Gregzz4
« Reply #17 on: April 15, 2010, 11:06:08 pm »
So, as we said, check your timings
If that doesn't help much, try a bigger carb
I love my Q-jet
Emissions are a breeze and Camaros are fun to surprise
'78 1/2 Ton
GMPP ZZ4 Q-Jet
3:42 Eaton
Offline eventhorizon66
'85 C10 SWB 350 700R4 TKO600
Offline tkleinia
« Reply #19 on: April 15, 2010, 11:11:14 pm »
Thanks everyone
I will re-check my timing and see how that works.
I will also look into the a/f gauge!
I still wouldnt mind the highway gear...
Offline Gregzz4
« Reply #20 on: April 15, 2010, 11:28:54 pm »
What do you mean by highway gear? You don't want to kill that great stroker with bad gears !!!!!!!!
Your 3:42 is perfect for city/street performance driving
What you need is to put a 700R4 back in there
I run factory tires and I am @ about 16-1700 RPM @ 80 MPH on a flat, whereas my old TH350 was giving me almost 3200 RPM !!!!!!
Just some more info to think about/spend money on
Get a 700 built to handle the power/torque and you'll never look back
Just make sure you research the carb connections for the TV cable and get the wiring for the lockup
Go here
http://www.bowtieoverdrives.com/index.shtml
PS: you can always PM me if you want info about installing a 700R4 where one was not before as I and a buddy have gone through many headaches with this conversion
« Last Edit: April 15, 2010, 11:36:58 pm by Gregzz4 »
'78 1/2 Ton
GMPP ZZ4 Q-Jet
3:42 Eaton
Offline Donut
« Reply #21 on: April 16, 2010, 03:50:51 am »
Timing, everybody has put you in the ballpark.
Cam specs would be helpful, especially since Vortecs are lift limited and you did say you still have the stock springs installed.  (ie. no "beehives", no mention of any head work to increase lift capacity)  Even my little Summit 1103 cam didn't have the lift clearance.
'73 Chevy K-20 ***SOLD***
350/tbh350/np205
'86 C-30 dually, 454/tbh400
