Author Topic: Pypes exhaust on lowered truck?  (Read 11771 times)
Offline jon volk
« on: April 18, 2010, 04:58:06 pm »
How much can you lower a C10 before you run into clearance issues with a pypes 2.5" dual exhaust? I have an 84 SWB at stock ride height at the moment. I dont have the exhaust installed yet so I have no reference to measure from.
Thanks in advance.
Offline HAULIN IT
Re: Pypes exhaust on lowered truck?
« Reply #1 on: April 18, 2010, 08:51:10 pm »
Welcome! Nice to see you on here Jon...I recognize the name from a couple other sites I frequent.
 As far as the exhaust goes, I have no first hand knowledge of the Pypes system, but if it's placed/bent well enough to use...other things should be a problem first ;) Post up some pic's! Lorne
Offline jon volk
« Reply #2 on: April 19, 2010, 02:28:47 pm »
Thanks! I definately recognize your name from at least the bullet. I figure the exhaust will probably fit a lowered truck without issue as its pretty common. I will most likely only do a 2/4 drop since I still use it as a truck and drive it through the winter.
Heres a couple pics.
The Caddy 500/TH400 thats going in it soon. Still need to address the oil pan, change the water pump and get some fresh ignition parts.
Offline treestandjunkie
« Reply #3 on: April 19, 2010, 04:06:02 pm »
Nice!
Offline SUX2BU99
« Reply #4 on: April 20, 2010, 07:02:54 pm »
Ohhhhhhh Cad 500 swap. That's definitely got my interest as I'd love to do one of these. Even a high-compression 472 would be fine by me! Let's see some more pics!
« Reply #5 on: April 26, 2010, 11:41:03 pm »
Owners have used them on trucks dropped 5/7.
