Author Topic: Security:  (Read 61055 times)
Re: Security:
« Reply #60 on: March 25, 2011, 01:06:02 am »
cant find em, grind em
Offline roger97338
Re: Security:
« Reply #61 on: March 26, 2011, 07:01:44 am »
Thats one reason I wanted a manual. Most average people dont know how to drive stick.
Great point. People that steal from other people don't seem to bother learning about anything. AT ALL.
« Last Edit: March 28, 2011, 08:06:01 pm by Captkaos »
Offline bake315
Re: Security:
« Reply #62 on: April 08, 2011, 10:33:57 pm »
Wouldn't that make them below average?  ;D
• '73 Cheyenne Super C20 454/400 http://forum.73-87chevytrucks.com/smforum/index.php?topic=7672.0
• ’79 Scottsdale K10 350/NP208/SM465 “Oscar” http://forum.73-87chevytrucks.com/smforum/index.php?topic=37885.0
Offline slammed79
  • Thou shalt not drive stock
Re: Security:
« Reply #63 on: April 09, 2011, 03:19:11 am »
Now that you mention it actually... hahaha!
Praise the lowered
Offline 1979C20
  • Kyle Taulton.
Re: Security:
« Reply #64 on: April 09, 2011, 03:45:06 am »
1979C20
One more post like that and you WILL be banned permanently. Capische?
« Last Edit: April 09, 2011, 08:20:08 am by VileZambonie »
Offline Stewart G Griffin
Re: Security:
« Reply #65 on: June 05, 2011, 12:10:57 pm »
What about suggestions for a fuel shutoff?
Would it basically go like this:
Use something like this(not nessesarily from speedway, but similar)
http://www.speedwaymotors.com/AN6-Fuel-Shut-Off-Valve,7911.html
Cut the original fuel line from pump to carb, taking out the appropriate amount to accomodate the the length of the shutoff.
Flare each side of the fuel line that you just cut, but first put the appropriate A/N or otherwise "female" (i don't like that term i wish there was another term) fittings
Then simply connect everything and you're done?
« Last Edit: June 05, 2011, 12:13:01 pm by Stewart G Griffin »
Re: Security:
« Reply #66 on: June 05, 2011, 02:08:51 pm »
It will still run with the fuel in the fuel bowl and if it dies while driving most theifs will just let it roll and jump out - now your truck is trashed. Not a very good security system. Open the ignition primary circuit and it will never run.
Re: Security:
« Reply #67 on: June 05, 2011, 03:13:33 pm »
Well, i was going to shut it off with the engine still running and let the bowl run dry.
How about great detail when installing the open ignition primary circuit?
Re: Security:
« Reply #68 on: June 05, 2011, 07:06:36 pm »
Install an interupt switch in the pick up coil circuit if you want to make it really simple.
Offline 1979C20
  • Kyle Taulton.
Re: Security:
« Reply #69 on: June 05, 2011, 07:20:45 pm »
You could even put the kill switch between the ignition wire and the starter solenoid. Some people get greative, like make the kill switch the turn signal  so you have to turn the left blinker on to start the truck.
Re: Security:
« Reply #70 on: June 05, 2011, 07:52:00 pm »
i need step by step instructions.
