Brakes and Braking Systems
Poor Braking
Topic: Poor Braking (Read 15457 times)
Edahall
Re: Poor Braking
Reply #15 on:
May 05, 2010, 11:23:11 am »
Update:
The brakes are working well. I put a vacuum gauge on the system and I was getting 25 inches of vacuum. I then checked the master cylinder reservoir and found that the fluid for the rear brakes was very low. I added brake fluid and took a test drive. After about 20 stops, the brakes started working normally.
1990 ¾ ton 4x4 Chevy Suburban
-Gear Vendors Overdrive
-Upgraded Holset HX-35 turbo
-NP205 iron transfer case
-3.73 gears
-2" Lift
eventhorizon66
Re: Poor Braking
Reply #16 on:
May 05, 2010, 07:13:25 pm »
If the MC was that low, it'd be a good idea to bleed the system.
'85 C10 SWB 350
700R4
TKO600
ccz145a
Re: Poor Braking
Reply #17 on:
May 06, 2010, 09:20:54 am »
And the fluid had to go somewhere, it's a closed system. Check your master, lines, hoses, calipers and cylinders and find out where it went.
Jacked85K10
Re: Poor Braking
Reply #18 on:
May 10, 2010, 12:16:51 am »
The whooshing noise you are hearing is a sign of a bad booster. When you pulled the vacuum line off the booster did you notice and brake fluid residue in the hose? If so consider replacing your master cylinder also.
Poor Braking
