Performance
454 timing
Topic: 454 timing (Read 8248 times)
micahadams
454 timing
April 28, 2010, 09:28:44 pm »
Does anyone else have a hard time starting(starter turning slow) w/ 15 degrees initial timing?
Last Edit: April 28, 2010, 11:33:09 pm by micahadams
Josh454
Re: 454 timing
April 29, 2010, 05:24:04 pm »
Wouldn't think so but then again what is your compression? Are you running headers?
micahadams
Re: 454 timing
April 29, 2010, 11:32:10 pm »
C/R is 8.5 and yea i have some thorley tri y's
Im going to put in a 2nd battery and see if that helps(came factory w/ 2 batteries)
beastie_3
Josh
Re: 454 timing
April 30, 2010, 12:40:02 am »
take your batteries and starter in and get them tested for free before you start dumping money
Semper Fi
joesgarage71
Wrench
Re: 454 timing
April 30, 2010, 02:04:28 am »
does it crank any faster if you move it to 4*?? If not
Make sure all the conections are clean, the battery is charged, grounds are good. if it still cranks slow I'd say the starter is junk. bushing worn out, armature is rubbing on the Field windings.
micahadams
Re: 454 timing
April 30, 2010, 07:30:44 pm »
Yea it cranks much better with less timing.
joesgarage71
Wrench
Re: 454 timing
May 01, 2010, 05:48:13 am »
something ain't right it shouldn't need that much timimg. timing chain worn, weights in the dist. rusty?
Balancer could be slipping on the rubber band.
Last Edit: May 01, 2010, 06:18:47 am by joesgarage71
micahadams
Re: 454 timing
May 01, 2010, 01:29:14 pm »
The HEI will only centrifical advance 20 degrees. So to get 35 total I need 15 initial. Motor is brand new w/ a brand new SFI balander
Adding the 2nd battery helped big time. It will crank much better now
malibu795
Re: 454 timing
May 01, 2010, 08:32:32 pm »
what are your battery cables like?
good grounds? perosnally i run a dedicated ground form the engine block to battery
a stock OEM starter should roll a 8:1 engine over no problem
adam wildman
75 K25 383/400
bgctrading
Re: 454 timing
May 03, 2010, 05:55:34 pm »
I never use anything but a good gear reduction starter anymore.
drag80
Re: 454 timing
May 03, 2010, 11:24:41 pm »
i'm using a smaller GM gear reduction starter, and it turns over my 10.5 to 1 compression 468 with ease, and i even have the distributor locked out, so it starts at 36 degrees timing.
Performance
454 timing
