Author Topic: Steering gear box rebuild  (Read 27547 times)
Offline alex
Re: Steering gear box rebuild
« Reply #15 on: June 12, 2010, 06:22:55 pm »
If adjusting a steering box it is important to follow the factory manual exactly;the gear must be removed from the truck and the worm bearing preload set first before setting the over center adjustment.Although not hard to do adjusting a steering box is a safety related item and should be done properly.
« Reply #16 on: June 12, 2010, 07:26:34 pm »
Quote
 ??? When initially setting up the gear box true the worm bearing preload is set first but the high point or sector lash adjustment can be done in the truck on an existing box.
