Author Topic: breather question  (Read 3122 times)
Offline 84chevysilverado
breather question
« on: April 29, 2010, 11:46:19 am »
Just a quick question here to all u guys running with an aftermaket air cleaner what did u do with the pcv valves? Mine had one pcv valve on he drivers side and no pcv on the passenger side and both went into the air cleaner. So this is what i was thinking put another pcv in the passenger side and attach those little breather air filters to the pcv valve. I no I cant get rid of the pcv valves. thanks marc
Offline eventhorizon66
Re: breather question
« Reply #1 on: April 29, 2010, 12:27:49 pm »
Breather on one cover, PCV on the other.  PCV connected to the air cleaner will not work properly.  It requires full engine vacuum, so you must connect it to the 3/8" vacuum port on the carb.
'85 C10 SWB 350 700R4 TKO600
« Reply #2 on: April 29, 2010, 02:07:24 pm »
ok so connect the pcv to the 3/8 vacume port on the carb and put a breather on the other thanks
