Author Topic: Is a 78 cab the same as a 74 cab ?  (Read 6136 times)
« on: May 01, 2010, 01:12:16 am »
  I have a 74 Chevy 1/2 ton step side 4WD truck and the cab from rocker to rocker has serious rust.  I found a 78 step side 4WD cab with no rust.  Instead of spending all the man hours to weld in all new panels, I was going to swap out cabs but have not got a straight answer on if they are the same cabs.  Anybody out there knows if they are the same.  Thanks.
Re: Is a 78 cab the same as a 74 cab ?
« Reply #1 on: May 01, 2010, 06:15:08 am »
They are very close to the same. The cabs will swap and be basically a direct bolt in. There may be some minor differences such as door panels, and possibly wiring harness differences, but I don't think there will be anything that can't be easily overcome. I put an 85 cab on a 76 chassis, and it was a direct bolt on. All I had to do was use the 85 engine to cab harness.
« Reply #2 on: May 01, 2010, 12:14:03 pm »
  Thanks for the help, I was wondering if the hood and fenders would work off my 74, and I hope they will.
« Reply #3 on: May 01, 2010, 09:10:02 pm »
The hood and fenders should bolt up no problem.
« Reply #4 on: May 01, 2010, 10:46:27 pm »
The only possible differences would be the washer wiper switch and headlight switch size/location.  Otherwise they are identical.
