Body, Glass & Paint
post up your homemade spray booths
Topic: post up your homemade spray booths (Read 9902 times)
2502
May 02, 2010, 01:36:22 am »
i know i'm not the only one spraying on here.
i spray the bikes outta my garage, or when i feel like it, in the driveway. i've had booths, but now i need to rig somethign in this new spot i'm heading into.
this weekend i sprayed a van outside. not too bad. only issue was my clear was too fast, and i had to dump it on heavy and run laps to keep it wet. there's a few flaws, believe it or not no bugs. just some dirt where i bumped my air line into it running.
the pics are a little outta order but u get the idea.
so who's got a booth and what are you using?
www.facebook.com/twenty502
80stepsideguy
Re: post up your homemade spray booths
May 06, 2010, 03:43:22 am »
Well its no booth yet but i gotta extend mine 8 feet longer then the pictured here.I will use this to paint my 01 ram this fall...And drape it with bisqueen clear plastic or maybe just regular plastic in a roll by a auto paint store ..
thanks
pat
Last Edit: May 06, 2010, 03:45:06 am by 80stepsideguy
1998 Chevy 1500 S/B 2wd
2502
May 06, 2010, 12:03:12 pm »
are those bed sides disassembled hanging there? that's how i was i thinking on spraying my bed
80stepsideguy
May 06, 2010, 01:01:07 pm »
Yes there just hanging, that way you can get under them and get everwhere needed..
thanks
pat
three8six
May 06, 2010, 01:13:22 pm »
thats exactly how we painted aircraft parts in the hangars, just wire em to "rolling clothesline"(easiest way to explain it) great way to do alot of peices at once
80stepsideguy
May 06, 2010, 01:36:16 pm »
Ours at work are on rolling racks. Thats how we paint our aircraft parts at work...
thanks
pat
2502
May 06, 2010, 05:23:08 pm »
that's how i do my bike parts, i always hang them on these clothes racks that have wheels at the bottom so i can move them around really easy.
ok here's a shot of the new engine so far, this is what he's suggested:
cam is 480 lift it willhave a little lope
so not sure what that even means. he asked what cam i wanted to use, so i sent him a reply asking him what heads he had to choose form and we'd go from there.
Canadian 4X4
May 06, 2010, 05:32:15 pm »
I work at a Marine store so I used shrink wrap you could make a permanent booth out side for the price of lumber and couple hundred dollars worth of plastic will last 2-3 up here and that is in snow and fairly high wind. I personally just used the shrink wrap in my garage and just stapled it to the roof and made the walls tall enough so they hang on the floor. Make sure you buy white or clear shrink wrap the blue will give the whole room a blue tinge as the light shines through.
Jesse Walter
May 06, 2010, 10:43:15 pm »
So is every car on your block covered in green paint and clear?
Jesse Walter
86 K20 4x4
86 C30 Dump
2502
May 06, 2010, 11:37:05 pm »
Quote from: Jesse Walter on May 06, 2010, 10:43:15 pm
absolutely not? i know how to spray. there's barely any overspray on the tires cuz they weren't covered either. tehy wanted thsi as cheap as they could get it, so they got it. now i notice the clear internet stores all over the city, and i'm wondering why with such a huge corporate backing they wanted a $500 paint job
Body, Glass & Paint
