Author Topic: Do I need to torque nuts holding lower control arm  (Read 4606 times)
Offline chronos
« on: May 10, 2010, 02:04:24 pm »
hoping to get a quick answer.....do the u-bolt nuts
that hold on the lower control arm need to be torqued or
just tighten them up good. Also My orginals don't look like they
had lock washers on them but I am going to use them
Going to put it back on tonite so please respond if you know,thanks
Offline overthepond
Re: Do I need to torque nuts holding lower control arm
« Reply #1 on: May 10, 2010, 04:56:25 pm »
Not sure on the torque numbers but my 'u' bolts have no lock washers either and mine is completely original..?
I think they would crack anyway with the weight stress upon them...sure someone will chime in with a better answer... ;D
Dave
« Reply #2 on: May 10, 2010, 05:00:07 pm »
I generally get them as tight as I can.  guessing but 60-80lbs.
There were no lock washers on them that I know of.
Offline chronos
« Reply #3 on: May 10, 2010, 05:41:34 pm »
Thanks , I will scrap the lock washers and tighten them good
