Author Topic: right turn signal light  (Read 13735 times)
Offline 86charcoalsierra
« on: May 12, 2010, 04:10:40 pm »
I got a 86 sierra classic that when i push the brake the right turn signal turns on but it dont blink and when i let the brake go it turns off. The brake light fuse keeps burning out what should i look at first.
Offline Grim 82
Re: right turn signal light
« Reply #1 on: May 12, 2010, 04:56:58 pm »
What does work? Do you have park lamps & turn signals? When you push the brake and the right signal turns on is it on in the front and the back?
Offline Josh454
« Reply #2 on: May 12, 2010, 07:19:19 pm »
Text book bad ground.
« Reply #3 on: May 13, 2010, 06:14:19 am »
« Reply #4 on: May 17, 2010, 10:28:18 pm »
I moved all the grounds and it still does the same thing. What should i check next.
« Reply #5 on: May 18, 2010, 12:02:57 am »
when you say turn signal do you mean at the tail lights or in the cab on the dash?
« Reply #6 on: May 18, 2010, 12:48:10 pm »
When i push the brake the right turn signal turns on the dash light lights up and so does the light out side they just dont blink.
« Reply #7 on: May 18, 2010, 12:53:11 pm »
Have you replaced your flasher? What happens when you put the hazards on? If the hazards work, then swap the hazard flasher with the turn signal flasher and see what happens. If it works=bad flasher.
« Reply #8 on: May 18, 2010, 01:04:06 pm »
Have you checked the bulb made sure its the right one
« Reply #9 on: May 20, 2010, 12:21:44 pm »
I got the problem fixed i changed the light bulb and it worked thanks for all the help.
