Author Topic: What's this??  (Read 5892 times)
Offline JC_32
    • Three Two Choppers
What's this??
« on: May 15, 2010, 10:06:12 am »
Will someone tell me what this is?
Also why do you think it would be in plugged??
Thanks in advance.
Re: What's this??
« Reply #1 on: May 15, 2010, 02:04:42 pm »
In plugged?
Offline DnStClr
Re: What's this??
« Reply #2 on: May 15, 2010, 03:09:37 pm »
The unit with the 2 wires is a solenoid and the unit tour finger is on is called the air injection control valve, or more commonly called e.a.c.- electric air control.  It's part of the emissions system.
Forgot to add- it gets a signal from the ecm.
« Last Edit: May 15, 2010, 03:12:58 pm by DnStClr »
Don
87 Chevy Silverado
Offline JC_32
Re: What's this??
« Reply #3 on: May 15, 2010, 08:23:56 pm »
In plugged?
ha ha that didn't make much sense did it?
I meant why it wouldn't be plugged in?
Offline mountaindrew
    • Picasa truck album
Re: What's this??
« Reply #4 on: May 16, 2010, 07:23:52 am »
If it stopped working and didn't correctly direct the pump's air it might have just been plugged instead of getting a new one.  If you have to get smogged you might have to unplug it or get a new valve and get it working again.  I completely removed the air pumps and those diverter valves on mine.  Mine caused the exhaust to pop or thump at idle plus I don't have emissions check.  There is absolutely nothing to gain, performance wise, by plugging it.
1986 Chevrolet C20 Silverado, C6P, 454, TH400, 3.73, FF
oil and trans cooler, 6 qt oil pan, p/w, p/l, air, cruise
17" Dodge wheels & E rated Michelins, Curtis hitch, Prodigy, Equal-i-zer
Offline JC_32
Re: What's this??
« Reply #5 on: May 16, 2010, 07:41:27 pm »
It was unplugged when I got the truck. When I plug it in, the motor whistles on acceleration?
I haven't been able to find anybody talking about theirs doing something similar?
Re: What's this??
« Reply #6 on: May 17, 2010, 12:26:56 pm »
Just take all that crap off if you don't have to pass a sniff test.  Air pumps, hoses, valves, etc. If you want to leave the pumps on there, just take off those big hoses going everywhere.  That alone will clean up your engine bay a lot.
Offline JC_32
Re: What's this??
« Reply #7 on: May 17, 2010, 04:41:05 pm »
Unfortunately, I think I have to pass a sniff test?
