Author Topic: Just getting started  (Read 5003 times)
Offline familyman
« on: May 16, 2010, 11:30:34 am »
Well the time has finally come to start working on the truck.  Sold my high school fixer upper(el camino) and now I get to build the C10.
This is what I have.
1983 C10 2wd swb 5.7
Now this truck will have to be a build as you go kind of thing, but before it goes on the road I have to swap the cab do to severe rust and the fact that I have a mint cab and nose clip for it.
While the nose+cab assembly is off I want to at least replace all the brake and fuel lines, fuel sending unit, brakes, bushings, and front end parts.
My question is involving the front end components and bushings, I have search the net some and have had a hard time with some of the sites (pst- performance)  What have you used for kits from where and price?
Also is there anything else I should rebuild, replace while the truck is tore down?
I probably won't modify ride height yet, so I'm just looking for a fresh chassis for the meantime.
Thanks for your help, you guys are awesome!
Re: Just getting started
« Reply #1 on: May 16, 2010, 11:46:55 am »
I always used P-S-T for the past decade.
Offline g2bird
« Reply #2 on: May 17, 2010, 09:20:04 am »
Another nice thing about these trucks is that most of the parts are available at your local parts store.  I just rebuilt all the front suspension on my truck and with the exception of the lowering springs everything else; bushings, ball joints, tie rod ends, bearings, new rotors, brake lines was available at O'reilly.  They carry Moog brand which has a lifetime warranty and you don't have to wait for it to be shipped.  All the little things do add up pretty fast though it was around $500 for everything, but if I remember right the rotors, brake lines and bearings were about $175.
Offline fbody
    • firebird and camaro
« Reply #3 on: May 18, 2010, 09:05:06 am »
true.. such a high production number every year these trucks and so many are on the road, that yes, parts are plentiful.  good luck and post some pics as you go!
Offline familyman
« Reply #4 on: May 18, 2010, 09:51:00 pm »
Thanks I'll look into that at my local parts store.  I'll post pics soon.
