Author Topic: steel roll pan install  (Read 7605 times)
Offline treepete
« on: May 17, 2010, 08:23:24 am »
Hi, i got my roll pan in the mail last week, and when I dry-fit it, its a little bit too long for the space between the bedsides. about 3/16.
is there some way to remedy this without sectioning the pan?
1983 Silverado
1999 Yukon Denali
Other problem: Off-Road R/C.     www.rccorral.com
Offline dv8customs
Re: steel roll pan install
« Reply #1 on: May 17, 2010, 11:58:06 am »
I would cut 3/32 off of each end
Offline treepete
« Reply #2 on: May 20, 2010, 08:33:04 am »
I investigated that, and each end has a rolled lip on it, and I wouldnt want to cut that off I dont think.
any other ideas? can the bedsides be adjusted in some way to make room?
1983 Silverado
1999 Yukon Denali
Offline dv8customs
« Reply #3 on: May 20, 2010, 02:45:46 pm »
Just weld it in, then the lip on the end won't matter  ;D
Offline treepete
« Reply #4 on: May 20, 2010, 03:29:15 pm »
dv8, thanks for your input. will removing the rolled edge compromise the structural integrity, since the pan will only be welded at the top portion?
1983 Silverado
1999 Yukon Denali
Offline 1980c10
« Reply #5 on: May 20, 2010, 09:46:27 pm »
cut the sides, weld the top and sides and smooth them in.
like this
[/URL][/img]
Offline dv8customs
« Reply #6 on: May 20, 2010, 10:41:47 pm »
Offline dv8customs
« Reply #7 on: May 20, 2010, 10:43:03 pm »
Weld the sides and do a little body work to smooth it out nice. Across the top I would drill a few holes and then plug weld them.
Offline 1980c10
« Reply #8 on: May 20, 2010, 11:27:52 pm »
That's exactly how I did mine in the above picture.
