Author Topic: Brake Line Extension Brackets ?  (Read 7062 times)
Offline AMK1001
« on: May 17, 2010, 06:41:32 pm »
I recently finished installing lift springs on one side of my truck. This is the '81 K20 that a previous owner had put blocks under the springs on the front.
I don't think I have enough slack on the rubber brake line. (see picture). The kit came with brake line extension brackets, but I'm leary about bending almost 30 year old metal brake lines to make them work. Are there any tips or tricks to doing this?
Re: Brake Line Extension Brackets ?
« Reply #1 on: May 17, 2010, 07:05:32 pm »
I recommend getting longer stainless steel braided lines.
« Reply #2 on: May 17, 2010, 07:10:41 pm »
If you use a large socket to bend the lines around, you SHOULDNT have any issues. Unless they are rusted.
« Reply #3 on: May 18, 2010, 12:30:30 am »
and if they do break i would say better now than down the road. but i would go for stainless brake line. rough country sells skyjackers brake lines
« Reply #4 on: May 18, 2010, 12:57:32 am »
If you do break it, they make stainless steel hard lines as well. But I think you have to buy the compete kit...As long as you use something hard with a large diameter radius, you should be fine.
Offline malibu795
« Reply #5 on: May 29, 2010, 05:55:39 am »
no you dont have enough slack.... if that is at ride hieght... that is what it should look like at full droop.. or littel more slack then that.
adam wildman
75 K25 383/400
