Author Topic: 700R4  (Read 19444 times)
Offline bobcooter
  • 1979 Scottsdale C-20
Re: 700R4
« Reply #15 on: May 21, 2010, 05:38:58 am »
Thanks, I'll let yall know how it turns out!
Offline bobcooter
Re: 700R4
« Reply #16 on: May 21, 2010, 10:03:15 pm »
Well I went and picked my transmission today. It took me 5 hours to travel 110 miles due to a wreck on I-12. A section of it was shutdown. 5 hours over and 1 1/2 hours back! Anyway, it was taking so long, the guy argeed to meet me a pretty good way from his house with the transmission. So, we're standing in O'Reilly's parking lot looking it over and I spot an  electrical plug. He said it has the electric lock up converter. He said one of the three wires was hot (ignition), one was ground and on I wouldn't need.
  Anybody know which color goes where?  Can't you run the hot wire through a toggle switch for a little more control of the OD?
 One more question: Is it a 700r4 or a 4L80E? Or did some 700r4 have electric lockup converters?
« Last Edit: May 21, 2010, 10:11:09 pm by bobcooter »
Re: 700R4
« Reply #17 on: May 22, 2010, 12:56:22 am »
wheres this plug at what does it look like. and it would be a 4l60e not the 80 if it was
Offline bobcooter
Re: 700R4
« Reply #18 on: May 22, 2010, 07:13:36 am »
Irish, it's on the driver's side about midway the length of the transmission. It is kind of rectanguler and it has has three wires coming out of it. At least I got the plug and the wires.
Offline jaredts
Re: 700R4
« Reply #19 on: May 25, 2010, 08:38:42 am »
Some 700R4's did have a lock up converter (I've had two).  There are some posts around here somewhere about locking it up with a switch.  I did a quick search and summit has a kit to control it automatically or with manual override (switch).  http://www.summitracing.com/parts/TCI-376600/
Offline 78Big10
Re: 700R4
« Reply #20 on: May 25, 2010, 08:37:02 pm »
Also 700s were never ecm controlled, they were renamed 4l60e when they went electronic.
NOT True! i have a 7oor4 from an 87 camaro 305 in my truck. it has a lock-up style torque converter which is computer controlled to lock in 3rd and 4th. for anywhere between about $75 and $150 you can get a stand alone controller for this style converter. kind of a hassle But worth it for the gas milage. my truck has 4.11 rear gearing so that Really helps me. totally drivable and holds iup to a mild small block 400 i think its a great choice good luck with your install!
Re: 700R4
« Reply #21 on: May 25, 2010, 08:45:49 pm »
All 700R4's (4L60's) had the lock up feature. The only difference is how it's controlled. If you do a search on the forum you will see this discussion with several solutions.
Offline bobcooter
Re: 700R4
« Reply #22 on: May 25, 2010, 08:52:18 pm »
Thanks, I found out which wire goes where. One is hot, (violet) one is ground (tan with a black stripe) and one you don't use at all (blue). The guy I bought it from said he installed one in his Chevelle with the same plug and he ran his hot wire through a toggle switch to turn the lock up on and off. I'm thinking the current TH-400 already has an ignition keyed hot wire running to it. I think I could route it to a toggle mounted on the dash. Any thoughts?
Re: 700R4
« Reply #23 on: May 25, 2010, 08:54:14 pm »
I would do it right or don't even bother hooking it up and just hook up an auxiliary cooler.
Offline bobcooter
Re: 700R4
« Reply #24 on: May 27, 2010, 05:08:03 am »
Vile, you're right. I believe that anything worth doing is worth doing right. Plus, it's so hot down here already, it would really hurt to have to pull it all back out. Thanks for all the input guys. I have learned a lot aboutthese trucks since joining this site. Your all the best.
jaredts, I keep a copy of Summit's catalog in my ....."library"  ;)but I did not notice that kit until you pointed it out. Thanks,
