Author Topic: timing for 292-6  (Read 3747 times)
Offline 77 cc lb
timing for 292-6
« on: May 20, 2010, 06:24:48 pm »
i can't seem to figure out the timing on '74 292-6. i had  harmonic balancer on 0*, and have dist. at #1 plug and all i get is backfire. is it supposed to be 2* btdc or more? could my points be off, they were set right, but might have gotten messed w/ me working in engine bay? any help would be greatly appreciated.
87 Chevy crewcab shortbed soon to have a 454/400
Re: timing for 292-6
« Reply #1 on: June 01, 2010, 02:01:31 pm »
I can't remember what it is supposed to be factory but I would start at 8 degrees.
Offline 77 cc lb
« Reply #2 on: June 02, 2010, 04:37:37 pm »
hey captkaos, i think i figured out my timing prob. i moved my wires back (counterclockwise) 2 spots and she started up, but runs rough. do i just need to loosen dist. and move until running smooth or should i try something else?
« Reply #3 on: June 02, 2010, 04:46:58 pm »
I would bring it back to TDC and set the distributor so you can advance it some and then put the plugs back on, BUT yeah, you should be able to loosen it to get it smoother.
Offline 77 cc lb
« Reply #4 on: June 02, 2010, 04:50:49 pm »
thanks for the help i will try that. i just posted another problem you be able to help with. thanks
