Author Topic: Input shaft spect sm 465  (Read 6827 times)
Offline BULLDOG
« on: May 21, 2010, 08:11:01 am »
Does anyone know the input shaft size and spine count for sm 465
Black 1983 K20 and sm 465
Re: Input shaft spect sm 465
« Reply #1 on: May 21, 2010, 02:44:41 pm »
What shaft. You talking about were you put the alignment tool in?
Offline BULLDOG
« Reply #2 on: May 21, 2010, 06:47:59 pm »
I have a friend that has a Center force pressure plate and DF clutch with low milage I need to know if the clutch spline count and shaft size will work with the center force clutch?
I am pretty sure that the clutch is 26 spline with a 1 1/8 inch shaft
« Reply #3 on: May 21, 2010, 07:06:13 pm »
What's his plate for?
Offline joesgarage71
  • Wrench
« Reply #4 on: May 21, 2010, 09:06:10 pm »
10 spline
« Reply #5 on: May 22, 2010, 01:12:33 am »
10 splines yes but more than likely its a 1-1/8" shaft but it might be a 1-1/2" shaft
Offline jaredts
« Reply #6 on: June 03, 2010, 06:35:00 am »
1-1/8" diameter 10 spline.  Did an internet search for "sm465 input shaft" and grabbed the first website that came up: http://www.novak-adapt.com/knowledge/sm465.htm.
« Reply #7 on: June 03, 2010, 11:09:43 pm »
Yes but there are two dif size shafts
Offline jaredts
« Reply #8 on: June 04, 2010, 05:35:14 am »
That website looked legit. and states only one input shaft size.  A few different output shafts.
Offline Grim 82
« Reply #9 on: June 04, 2010, 09:39:46 am »
http://www.4wheeloffroad.com/brandpages/chevy/131_0208_sm465_transmission_rebuild/index.html
Irish is right. Bulldog, if its for a 465 it will be 10 spline, but it will be 1 of 2 shaft diameters. Do you know what vehicle application the centerforce was used on?
