Author Topic: Rear Brake leveling/propertioning thingy  (Read 4529 times)
Offline Mild Thunder
« on: May 22, 2010, 08:18:11 pm »
Hey guys. Just picked up a 1989 R3500 crew cab dually. Put on new rear shoes, adjusted them, and still the brakes dont feel that great. Read somewhere that the rear height sensing valve could be not allowing full rear braking action. Is there a way i can disconnect the rod that goes to it and wire it to the full open position? This truck will be used to pull a boat in the summer, and not in the winter at all.
Also, when i come to a stoplight, the pedal sinks a tiny bit after having my foot on it for about 5-10 seconds. Not to the floor, but just a bit. No leaks anywhere, and not losing fluid. Not sure if this is a charactoristic of the hydroboost?
Offline mountaindrew
    • Picasa truck album
Re: Rear Brake leveling/propertioning thingy
« Reply #1 on: May 23, 2010, 09:30:32 pm »
Hydroboost should have that thing stopping on a dime.  Somebody with experience will chime in any time.
1986 Chevrolet C20 Silverado, C6P, 454, TH400, 3.73, FF
oil and trans cooler, 6 qt oil pan, p/w, p/l, air, cruise
17" Dodge wheels & E rated Michelins, Curtis hitch, Prodigy, Equal-i-zer
Offline 79k30guy
« Reply #2 on: May 23, 2010, 11:21:04 pm »
regarding your brake issue at stoplights...
I had literally the same issue on my 1 ton.   It was the master cylinder.  with a core charge refund, it was a $20 fix..
« Reply #3 on: May 29, 2010, 12:16:04 pm »
Did the new master give the brakes a better feel/power? Or just fix the sinking pedal?
Offline 79k30guy
« Reply #4 on: May 31, 2010, 11:18:20 am »
I'm not sure the brakes stop the truck better, if they do its hardly a noticable difference..   it definantly fixed the slowly-sinking pedal.
