Author Topic: Factory Tach Swap into an 87  (Read 4788 times)
Offline Low87c10
« on: May 31, 2010, 06:53:23 pm »
I have an instrument panel with the factory tach that I'd like to put into my 87. The panel is all electric, and I know that I will need to use the original 1987 speedometer. Does anyone know of a source for a wiring diagram so I can re-pin the connectors? Any surprises I should watch out for?
Thanx!
Offline topp
Re: Factory Tach Swap into an 87
« Reply #1 on: May 31, 2010, 08:38:15 pm »
You must wire it manually from the Dist.
The 87 uses VSS and the tach feed for that can NOT be shared
'90 Suburban TBI 350
Offline slamd83c10
« Reply #2 on: May 31, 2010, 10:31:38 pm »
exactly
Offline dahoyle
« Reply #3 on: May 31, 2010, 11:27:12 pm »
Thanx!
There is a pic of how I did mine in the following thread.
http://www.fullsizechevy.com/showthread.php?424327-Instrument-Cluster-W-Tach
