Author Topic: 82 GMC 1/2 ton pickup 6 bolt rim compatibility?  (Read 3819 times)
Offline Joemt
« on: June 02, 2010, 10:40:38 pm »
I need a set of GM rims for my truck. What year OEM truck rims are compatible?  I just had the center crack out of the rim and that means drum with wrinkled fender lying on the ground...sucked.
Thanks for your help
Offline Grim 82
Re: 82 GMC 1/2 ton pickup 6 bolt rim compatibility?
« Reply #1 on: June 02, 2010, 11:08:24 pm »
73-87(91) 6-lug should be the same. Newer models with IFS will be the same bolt pattern, but the center hole will not clear the hubs of a solid front axle if memory serves me correctly.
