Author Topic: breaking nose cones on starters  (Read 6087 times)
Offline cpegasus
« on: October 19, 2002, 11:44:00 am »
the truck has broken 2 nose cones now and I have tried many different shim combinations it sounds best with none but then it eats the starter it is a 77 K10 with I believe a 400 that's what it came with and it is externally balanced incase it matters it has a 4 speed with a 205 transfer case I'm just out of ideas the flywheel looks fine on a tooth by tooth inspection any ideas would be appreciated
roundeline
  • Guest
Starter Problems
« Reply #1 on: October 19, 2002, 10:10:00 pm »
cpegasus,
I can't offer any personal help, but I did run across this link that might be helpful.
www.chevytalk.org/forums/Forum45/HTML/008319.html
I hope this helps.
Matt
Offline cpegasus
thanks
« Reply #2 on: October 20, 2002, 11:51:00 pm »
thanks for the info if the new ring gear dosnt solve it there is a tip there that might
Carol
