Author Topic: Name that jingle!!  (Read 10912 times)
Offline 1981 ss chevy
Name that jingle!!
« on: June 09, 2010, 04:33:49 pm »
I have a problem with my 81 2wd c10 chevy it has a 305 and th 350 tranny.  Recently my bro and me put on an edlebrock intake and carb, once we were done we took it out for that sweet first ride and it makes alot of power but now there is something jingling around in the frontend.  To be honest it sounds like dropping a wrench on cement repeatedly.  So i jacked up the front and checked everything and still cant find anything.  I understand that figuring out what a strange noise could be is somewhat difficult and basically a stab in the dark but Its bothering the heck outta me so does anyone have any idea what this strange noise could be??
Offline Grim 82
Re: Name that jingle!!
« Reply #1 on: June 09, 2010, 04:59:54 pm »
Are you missing any tools? ;D Make sure everything that spins is tight, nothing could be swinging in the path of the fan, and that the shroud is secured. I have been trying to track down a clicking sound myself.
« Reply #2 on: June 09, 2010, 05:03:26 pm »
No i have all my tools lol, and i checked everything its all secure
« Reply #3 on: June 09, 2010, 06:06:25 pm »
Do you have your ac compressor still? My 81 had a similar sound, and it was the clutch on the ac compressor. Also check to make sure the outter ring on the balancer hasnt come loose. Ive had it do it too.
Offline Lt.Del
  • Andy aka:SgtDel
  • DelbridgePhotography.com
    • www.delbridge.net
« Reply #4 on: June 09, 2010, 09:42:40 pm »
does the jingle increase with rpms?  Does it happen when you run over bumps in the road?  Did you jack up the front end and check play on suspension parts and wheel bearings? In other words, is there a pattern when you hear it?
Check your flexplate for damage, ring gear, starter, waterpump etc.
« Reply #5 on: June 10, 2010, 11:16:52 am »
no i took the ac out it didnt work and its only when i hit bumps.  Yes i checked all the suspension that was my first guess.
« Reply #6 on: June 10, 2010, 12:15:58 pm »
There is a tool, bracket, or bolt that is bouncing around somewhere or you forgot to hook something back up or something moved because of the swap and it is hitting something else.
Take off the hood and have someone sit in the fenderwell and drive down the road. Ok dont do that, but unless you guys did something else and forgot to tell us or dont think its important, a carb and intake swap shouldnt cause a jingle without something being loose or tools left in the truck.
Offline Grim 82
« Reply #7 on: June 10, 2010, 01:08:29 pm »
If you installed a tin can fuel filter with that edelbrock carb make sure it isn't bouncing against the valve cover or something.
« Reply #8 on: June 10, 2010, 01:10:32 pm »
Try to rock the truck when its parked to see if there is a sound then if there is pin point it
« Reply #9 on: June 10, 2010, 02:40:20 pm »
its not the fuel filter and everything is hooked back up i double checked everything today however the vacuum line that runs to the tranny got a lil bent could it be hitting the firewall maybe?
Offline Lt.Del
  • Andy aka:SgtDel
    • www.delbridge.net
« Reply #10 on: June 10, 2010, 02:43:58 pm »
Quote
I don't think that would be it, it wouldn't make too much sound. But, to rule it out, take some duct tape and tape a rag between the metal line the firewall.
« Reply #11 on: June 10, 2010, 02:49:21 pm »
k will do but also i'm gonna triple check all my suspension and intake/carb
Offline jaredts
« Reply #12 on: June 11, 2010, 06:53:28 am »
Unrelated to your swap, but a broken end link on a sway bar can make a similar noise.
« Reply #13 on: June 11, 2010, 12:25:54 pm »
Rock the truck baby
« Reply #14 on: June 14, 2010, 01:00:48 am »
I rock the truck but it wont make the noise, it only happens when im driving
