Author Topic: lifting a 2wd  (Read 20362 times)
Re: lifting a 2wd
« Reply #15 on: June 25, 2010, 05:15:51 pm »
Looks good!
Offline markdilljr
  • Me on Hopper "Covered"
Re: lifting a 2wd
« Reply #16 on: June 25, 2010, 06:24:03 pm »
Thank You, now I have to remove a leaf or two for a smoother ride which will lower the rear which means I will have add a 2 inch block to even it out. Its slow going but atleast its coming along.
Ride Rank, Make Bank
Offline three8six
Re: lifting a 2wd
« Reply #17 on: June 27, 2010, 09:31:08 am »
looks solid man
Offline malibu795
Re: lifting a 2wd
« Reply #18 on: June 27, 2010, 09:39:15 am »
how far is the upper A-arm form full droop stop?
stance looks good!
adam wildman
75 K25 383/400
Offline markdilljr
Re: lifting a 2wd
« Reply #19 on: June 27, 2010, 01:36:18 pm »
not sure about upper a-arm I can measure if you need me to, with the new springs the ride is very rough when I go over a speed bump ( even at 3 mph ) the front end jumps over it, every little bump feels like your hitting big rocks at 60 mph. If I cant find another option on lifting with a better ride ( I cant take it offroad like this ) I am thinking of lowering it. I like the look of Viles black one that he made into a short bed
Offline malibu795
Re: lifting a 2wd
« Reply #20 on: July 02, 2010, 02:25:29 pm »
check the following
distance between compression bump stop(dont think your on it because fo the heaverir springs you put in them)
distance between droop bump stop. could explain rough ride going over bumps
shocks do/can they travel farther then the shock mounts at full droop . ideally .5-1" farther
adam wildman
75 K25 383/400
