Author Topic: lifting a 2wd  (Read 20361 times)
Offline markdilljr
  • Me on Hopper "Covered"
lifting a 2wd
« on: June 22, 2010, 02:07:11 pm »
I got an 84 C10 long bed 1/2 ton and I want to lift the truck alittle, I had to swap rear ends and when I did the new leafs were longer and lifted the rear about 2 inches, I have a broke coil so I need to get new ones but cant find anyone selling lifted ones for my truck. Any ideas ?
Ride Rank, Make Bank
Re: lifting a 2wd
« Reply #1 on: June 22, 2010, 02:32:58 pm »
You can put 1 Ton springs in there to lift it.
Offline markdilljr
Re: lifting a 2wd
« Reply #2 on: June 22, 2010, 02:42:41 pm »
will that make the ride alot rougher
Re: lifting a 2wd
« Reply #3 on: June 22, 2010, 03:05:15 pm »
Anytime you lift something the ride is going to change.
Offline markdilljr
Re: lifting a 2wd
« Reply #4 on: June 22, 2010, 03:48:00 pm »
ok thank you I will look for a pair of 1 ton springs
Offline markdilljr
Re: lifting a 2wd
« Reply #5 on: June 22, 2010, 07:41:45 pm »
I just found a pair of 2 inch lifted springs for the half ton, there was a company making the 2wd lift but stoped making them about 2-3 years ago and I found a guy on craigslist that had the whole 2wd lift kit, I bought the coil springs for $30 thats cheap for the springs right or did I over pay?
Offline three8six
Re: lifting a 2wd
« Reply #6 on: June 22, 2010, 07:43:28 pm »
Good price, I will say though theres definetely potential for alignment problems when lifting that much with a coil. I woulda looked for a lift spindle maybe?
Offline markdilljr
Re: lifting a 2wd
« Reply #7 on: June 22, 2010, 08:58:45 pm »
no one makes any lift products for the 2wd anymore, 2 inch on a coil isnt much. A camber- caster adjust should do fine, maybe a shim or two but it wont be that bad
Offline Da67goatman
  • Burban
Re: lifting a 2wd
« Reply #8 on: June 22, 2010, 09:33:44 pm »
Fabtech used to make lift spindles, there is another thread on 2wd lift if you search for it.
<Pitcrew>
Offline heavychevy91
  • '86 Chevy K20
Re: lifting a 2wd
« Reply #9 on: June 23, 2010, 12:19:38 pm »
I did as Capt said with the 1T coils and it dosent ride too much rougher
Offline 78 Chevyrado
  • Z62 ON-ROAD
    • My Photobucket Site
Re: lifting a 2wd
« Reply #10 on: June 23, 2010, 01:25:42 pm »
Lifted mine with 1T coils too.  worked fine and had no alignment problems.
Offline velojym
Re: lifting a 2wd
« Reply #11 on: June 23, 2010, 05:09:22 pm »
How much lift does that give you? While I kinda like the rakish stance my '86 has right now, I like a level truck even better.
  • '86 Chevy K20
Re: lifting a 2wd
« Reply #12 on: June 24, 2010, 05:51:33 pm »
when the springs were new the lift was almost 3" but it settled to about 1" or 1 1/2" after almost a year. still nat a bad way for a cheap easy lift. i did buy the springs new though.
Offline markdilljr
Re: lifting a 2wd
« Reply #13 on: June 25, 2010, 04:19:01 pm »
Before the lift, old spring vs new lifted spring
Offline markdilljr
Re: lifting a 2wd
« Reply #14 on: June 25, 2010, 04:20:06 pm »
After the lift
