Author Topic: neutral safety switch  (Read 5269 times)
Offline 85k25
« on: June 22, 2010, 11:09:14 pm »
I need to change the neutral safety switch in my 83 3/4 ton but i'm having an issue with the replacement part.  I have the switch that is held in place by two small screws at either end and the only replacement part i can find are a snap in style.  Will this part work with my set-up or do i have to go with an older style switch?  Thanks in advance for any help.  ryan
Re: neutral safety switch
« Reply #1 on: June 23, 2010, 12:09:25 am »
it was in pre 80s pick ups
Offline 85k25
« Reply #2 on: June 23, 2010, 11:24:18 am »
looks similar but mine only has 4 terminals.  The mounting tabs are the same though.  Someone must have rigged it in the past.  Thanks for the help
