Author Topic: Yet another wheel/tire question from a newbie!  (Read 7438 times)
Offline Tarik
« on: June 24, 2010, 08:34:30 pm »
Sorry about starting another tire size thread, but I searched the archives and couldn't quite find an answer...  I just picked up a '79 2WD Stepside that needs tires and wheels badly.  Right now the rears are 275/60/15 and the fronts are 235/75/15.  The front wheels are American Racing wagon wheels, and the rears are no-name wagon wheels that are badly rusted.  I like the stance of the 275/60/15s and was thinking of putting them all around on 15x8 wheels, but I just read about the rear track being narrower than the front and am wondering if this will look awkward?  For that reason I'm considering a 235/70/15 in the front, which is exactly the same height as the 275/60/15 but obviously narrower.  The truck will mostly be a fun beater/cruiser, but may occaisionally tow an old racecar as well.  Then I was also considering 255/70/15s as they may fill the wheel wells better, but I like the look of the wider tire...  I'm very undecided!  Any advice is very much appreciated!
Attached photo is the wheel I'm considering ($43 @ Summit Racing!)
-Tarik
Offline team39763
Re: Yet another wheel/tire question from a newbie!
« Reply #1 on: June 24, 2010, 10:53:08 pm »
I think it'll work out with 235's up front. I believe that's what's on my truck right now.  I have 15X8's all around and 275/60's in back.  My wheels are stock rallye wheels and I'm not sure of the backspace or offset.
Offline Tarik
« Reply #2 on: June 25, 2010, 08:32:50 pm »
I'm being a little bit indecisive here...  Cragar makes the wheel pictured below in 15x8 in both a 4" and 5" backspace...  Would it be a good idea to run the 4" on the back and the 5" on the front with the same tire size all around?  Maybe 265/60/15 or 255/70/15?  I like the wheel in my original post better, but it only comes with a 3.75" backspace.  For some reason I'm really having a hard time making up my mind on this issue!
Offline Tarik
« Reply #3 on: June 25, 2010, 08:37:43 pm »
Whoops!  Attached the wrong picture above (that's my truck), and my browser crashed when I tried to change it...  Here's the other wheel I'm considering:
« Reply #4 on: June 26, 2010, 01:02:28 am »
truck pic doesnt work
Offline Tarik
« Reply #5 on: June 27, 2010, 07:03:40 pm »
Well, I'm pretty much decided...  I think I'm going with the Cragar in my original post on all four corners (15x8 w/3.75 BS).  I'm going to run a 275/60/15 in the back, with a 235/70/15 in front.  They have the same outside diameter but the section width is 1.5" different, which should help even out the front/rear track difference.  The only other choice I'm stll contemplating is 255/70/15 all around, with 5" BS up front and 4" BS in the rear, although I'm thinking that may pull the fronts in a little bit too far...
Comments/suggestions/pictures are very welcome!
Offline Tarik
« Reply #6 on: July 01, 2010, 02:11:47 pm »
Thanks, Team39763.  I think I'll go with the same setup (15x8s all around, 275/60/15 in back, 235/70/15 up front).  The Cragars I'm planning on getting have 1/4" less backspace than stock (3.75"), but I really don't think that's enough of a difference to cause any kind of rubbing with a stock suspension.  Does your track width look somewhat balanced visually?
Offline team39763
« Reply #7 on: July 01, 2010, 09:33:25 pm »
I just went and looked and I have 235/75/15's up front.  It actually does look somewhat balanced.  When I first bought the truck I had 15X10's all around with 275/50's all around and the front seemed to stick out a tad more and I hated it.  I like this look better, but I'm lowered so I think that has a lot to do with it.  My wheels seem to just barely tuck and I like that.
