Author Topic: rear window glass  (Read 7440 times)
Offline markdilljr
  • Me on Hopper "Covered"
rear window glass
« on: June 26, 2010, 08:43:45 pm »
My 84 C10 has the sliding rear window, I just picked up the solid glass for it and was wondering how to remove the sliding window without damaging the gasket. I need to re-use the gasket on the new glass. I know how to put it in, just dont know how to remove without causing damage to the gasket, anyone know how to do this
Ride Rank, Make Bank
Re: rear window glass
« Reply #1 on: June 27, 2010, 04:49:07 pm »
I use a broad edge pry bar an push the rubber out past the pinch weld.
Offline canadiandave78
« Reply #2 on: June 28, 2010, 02:03:43 pm »
there are 2 different ways that the moulding is shaped for.some will roll in toward the cab and others will roll out. The lip on the moulding will be around the outside edge...a easy example is pop your lights out if you have the rubber seal around them. Like every custom flat deck has..****you can also use a big flat pry bar***  hope this helps, spent a cpl years doin autoglass
Canadian Dave
Offline markdilljr
« Reply #3 on: June 28, 2010, 02:27:51 pm »
what lights are you talking about, whats that got to do with the window glass, maybe I misunderstood you
« Reply #4 on: June 28, 2010, 07:29:18 pm »
As a smaller example look at the way the moulding on the lights fits in. in the picture i added you can see the moulding but on a truck its not so deep..the rubber should have an H shape if you were to cut it. Another example is in a SKIDSTEER, you can only pop the back window out not into the cab..Im lookin for a photo of just the rearwindow but no luck yet
Offline markdilljr
« Reply #5 on: June 28, 2010, 07:53:18 pm »
still dont understand what lights you are talking about, what do lights have to do with the rear window. Its already done but tryin to figure out what you are talking about What Lights
« Reply #6 on: June 28, 2010, 10:06:28 pm »
Start at the corner and start rolling the gasket put with some pressure on it
Offline markdilljr
« Reply #7 on: June 28, 2010, 10:11:17 pm »
Thanks Capt. worked perfect, only took about 5 min to get it out and another 5 min to get the one peice window in. Looks alot better than the slider
