Author Topic: 4x4 front hub inserts for my 77?  (Read 4836 times)
Offline 77 4x4
« on: July 11, 2010, 10:51:52 am »
Need the stock 4x4 emblems/inserts for the front hubs.  Can't seem to find them anywhere.  Also, has anyone mounted 33x12.50 tires on a 8 inch rally?  Does it work?  TIA
Offline bmaier
Re: 4x4 front hub inserts for my 77?
« Reply #1 on: July 11, 2010, 02:15:27 pm »
Not sure where to find the 4x4 inserts but I do know that 33's fit on the rallys.
« Reply #2 on: July 11, 2010, 07:37:17 pm »
Someone on here mounted something like that. If u ask me it probably will cause premature tire wear unless you under inflate them but that will cause tire wear also. About the 4x4 stickers I would switch to manual hubs much stronger
Offline 77 4x4
« Reply #3 on: July 11, 2010, 09:39:50 pm »
Thanks guys.  Irish, I don't really have a need for manual hubs.  I don't do heavy duty trail riding or mudding in this thing.  I just like the 4x4 stickers on the front and back.  Yes, they certainly will cause premature wear, but man they will look good.  It is not a driver so I am not terribly worried about that.  Thanks for the advice guys.
« Reply #4 on: July 12, 2010, 01:05:48 am »
heres another thing about auto hubs they can fail on you and you not know it till you go to use them
Offline 77 4x4
« Reply #5 on: July 12, 2010, 05:01:58 pm »
Irish, didn't think about that.  Will do some research on it and may change to manual hubs.  Thanks my man!
