Author Topic: Converting 1/2 ton front to 8 lug with 3/4 ton parts?  (Read 5858 times)
Offline Mtrhd329
« on: July 11, 2010, 08:38:51 pm »
So i blew out my stock....i think it was 12 bolt?  lol  I cant remember now.  Found a 14 bolt out of a wrcked 1 ton and the guy gave me LCA's, rotors/hubs, and springs from the 1 ton.  My problem now is that i have street tires on 5 lug rims in the front and all terrains on 8 lug rims in the back.  I have done some research but the best i can see it would be easier to swap the front to 8 lug to match.  I could go 6 lug front and back but that is more work than i think just doing the front.
So what is the difference between the rotors on 1/2 tons and 3/4 tons.
Re: Converting 1/2 ton front to 8 lug with 3/4 ton parts?
« Reply #1 on: July 12, 2010, 01:13:08 am »
8 lugs ;D bigger brakes and other suspension parts 1/2 ton to 3/4 ton ain't hard same frame. just the 1 ton might be a little harder
Offline Mtrhd329
« Reply #2 on: July 20, 2010, 04:06:48 pm »
Anyone else?
« Reply #3 on: July 20, 2010, 06:26:55 pm »
To get 8 lugs you need to swap the control arms out.
Offline Mtrhd329
« Reply #4 on: July 20, 2010, 08:54:40 pm »
he only gave me lower so would 3/4 ton lowers and 3/4 ton upper ball joints on 1/2 ton uppers work?
« Reply #5 on: July 20, 2010, 11:50:35 pm »
did he give you 3/4 or 1 ton?
Offline Mtrhd329
« Reply #6 on: July 21, 2010, 05:52:42 pm »
he said 1 ton but i just figured it was 3/4 ton since it was a 14 bolt ff axle and 2wd.  what is the difference between 3/4 ton and 1 ton?
