Author Topic: Going to refinish my ralleys*  (Read 6833 times)
Offline greatdane
« on: July 12, 2010, 11:06:36 am »
I have decided that I want to refinish my ralleys on my 82. What works best powder coat? Looking to spend as little $ as possible. Can I see pics of some of yours and what you did to them....
« Last Edit: July 12, 2010, 11:28:29 am by greatdane »
'74 AMC Matador 2dr Coupe
Offline three8six
Re: Going to refinish my ralleys*
« Reply #1 on: July 12, 2010, 11:44:55 am »
Powder coating runs around 200$ for a set of four here. Paint for it, I would imagine couldnt run you more than 50$ if you did it yourself. I have painted a set of ralleys before and it did stick well though, I got my impala SS wheels being powdercoated anyways because a relative does it as a side business and helped me out. I have always had good luck with painting wheels though as far as it staying on there.
Offline rwhit57
« Reply #2 on: July 18, 2010, 10:18:36 pm »
Hey Fellow Okie, I've painted alot of Rallye wheels. There are 2 types of spray paint that I've found work well. Duplicolor Steel Wheels and the color is Steel Wheels, the other is made by Plasti-Kote and is Dull Aluminum. I use black engine enamel on the backsides. I sometimes strip the center caps under the old gray they are all chrome.
Randy from Okla
Whoever said "Money can't buy happiness" has obviously never seen a speed shop!
Offline team39763
« Reply #3 on: July 19, 2010, 02:24:30 pm »
I did my rallye wheels in black and I used the duplicolor high heat engine paint about 3 or 4 years ago and they still clean up decent.  They make that paint in aluminum silver, but I think you're better off going with what rwhit57 said if you want the classic look.
Offline 78 Chevyrado
  • Z62 ON-ROAD
    • My Photobucket Site
« Reply #4 on: July 27, 2010, 07:45:51 am »
Here's how I painted mine on my 87.   The outer part of the wheel is done in black so brake dust isnt a problem.  also painted the center cap base black.
Offline TxFiddler
« Reply #5 on: July 27, 2010, 10:02:36 am »
I have read some good things about Eastwood's Paint.  Here's a link http://www.eastwood.com/ew-rally-wheel-paint-silver-aerosol-12-oz.html.  This is what I will use when I redo mine.  Has anyone else used this before?  If so, any comments?
80 C10 2wd / 427 BigBlock / 700R4 / 3:42 Eaton Posi LSD / 770 cfm Holley Street Avenger / Doug's Headers / MSD ProBillet Distributor / Champion 3 row Radiator
