Author Topic: Measurement Questions for LWB-SWB Conversion  (Read 10123 times)
Offline 86gmc23
« on: July 13, 2010, 08:30:20 pm »
Hey guys just picked up my first 1986 c10 LWB and looking to convert it into SWB. I read the articles on it here but no one modified the bed to fit, they just bought a SWB bed to install. Has anyone cut a LWB bed to fit the SWB or know where to make the cuts and how much? And for the frame cut is it 12" by the cab and 2" out back? Any suggestions would be great and when I start project I will post pictures.
Offline Swims350
    • Cars and trucks
Re: Measurement Questions for LWB-SWB Conversion
« Reply #1 on: July 13, 2010, 08:59:35 pm »
That same thread had pictures and info about cutting the frame I'm pretty sure and it'd be vile's thread.
www.cardomain.com/id/benwa454
Offline 86gmc23
« Reply #2 on: July 13, 2010, 09:23:16 pm »
Really interested in the bed modifications.
Offline Swims350
    • Cars and trucks
« Reply #3 on: July 13, 2010, 10:05:01 pm »
Well the only bed mods I remember in the thread were him buying the short bed floor, front panel, tailgate, and bedsides.
Other then the customizatons he done to it, roll pan, tailgate skin, caddy lights.
Offline 1HI4x4
  • V30 Crew now a shortbed.....
« Reply #4 on: July 14, 2010, 05:25:37 am »
14" in front of the rear end, I took about 4" off the rear.
1988 V30 Crew Cab, Cummins power, 47RH-NP205, 8" lift, 13.50x35x20 Fuel Mudders on 20x14 XD Diesels -76 offset. Soon to be repainted, seats from a 2010 Lariat to be installed.
« Reply #5 on: July 14, 2010, 01:34:25 pm »
You are looking at some serious fab work to cut a LWB down to a SWB, the lower bed pieces are going to be a nightmare.  Hence why it is cheaper to buy a SWB bed.
The bedsides at the bottom are not straight, so you will have to pie those pieces to make it work.
Offline 86gmc23
« Reply #6 on: July 14, 2010, 10:16:05 pm »
I look further into when truck gets here on Friday. Thanks to AAA car is getting towed 80 miles for FREE   ;D. Had a question on fuel tank needed with this conversion. Found this but dont know which one would be needed.
http://www.jcwhitney.com/replacement-gas-tanks-for-cars-and-trucks/p2005688.jcwx
http://www.jcwhitney.com/no-rust-polyethylene-gas-tanks/p2005691.jcwx
« Last Edit: July 14, 2010, 10:22:32 pm by 86gmc23 »
Offline 1HI4x4
« Reply #7 on: July 15, 2010, 05:44:27 am »
I used a Blazer/Suburban tank mounted behind the rear end, you can use the smaller tanks(11 gallon) that mount in the stock location.
Chris sells them both. http://store.73-87chevytrucks.com/merchant2
Offline 86gmc23
« Reply #8 on: July 15, 2010, 11:51:47 am »
Don't see a tank in there, but see some stuff I will most likely be purchasing pretty soon.
« Reply #9 on: July 15, 2010, 02:24:06 pm »
Tanks are hit or miss on availability, so when you need them email me.
You will need a 16 gallon tank when you shorten it.
