Author Topic: big block carb  (Read 3703 times)
Offline 85k25
big block carb
« on: July 14, 2010, 10:50:15 am »
I'm trying to decide on a carb for my 454.  It will be in an 85 3/4ton which is mainly used for a daily driver with occasional tow/haul use.  The motor will be stock compression, stock heads, edelbrock performer intake, headers, and a 800 to 4800rpm tow cam.  I currently have an edelbrock performer 600cfm carb.  Will this be enough carb for me or do i need to step up to a 750?  Thanks in advance.
Re: big block carb
« Reply #1 on: July 14, 2010, 01:36:38 pm »
If you don't plan to be racing with it what you have will work.  at 100% VE (impossible) a 454 turning 5000rpms needs 650cfm.  At 83% VE (realistic) it needs 545cfm
Offline 85k25
Re: big block carb
« Reply #2 on: July 14, 2010, 11:45:48 pm »
thanks alot.  I was thinking that i would have enough carb but i wanted a second opinion from somebody with more experience.
